Greetings Ladies and Gents,
I'm running into an issue when trying to draw a line from Station offset on an alignment, where i can no longer select a different alignment after having run the command first.
I will use the "Create Line by station/ offset" , select alignment "A", and then type in my station and offset values. like show in my first screenshot.
However when i repeat this process, it will automatically select alignment "A" as the baseline and i can no longer choose a different alignment unless i close and reopen the file.
Im running C3D 2018 on windows 10 and dont have any weird disruptive settings to the best of my knowledge.
Thanks, -Scott
Thanks, -Scott
I didn’t know you could change alignments on the fly
Joe Bouza
Joe Bouza
