Static Text in dynamic labels
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone!
I'm wondering if there's a functionality in AutoCAD/Civil3D where I can have a label with both static and dynamic text?
I have a drawing where I used labels to annotate alignment stations and offsets at various points. I then manually entered static text into the label to annotate which object I'm calling out the station and offset of. The issue that I'm running into is that if I want to change the style of a label (station and offset, dynamic parts), the manually entered static text disappears as it is not part of the label style. Is there a way to change a label style without erasing the manually entered static text? I tried messing around with label text components but it seems like that doesn't solve my issue.
My alternative is to use a multileader for the static text and leave only dynamic text in the label, but that makes for 2 separate annotations that I have to put together "by eye" and it usually doesn't look good, has gaps, or is misaligned. Maybe there's a way to attach a multileader and label to move together as one entity? (not talking about the group command because that is no help)
Thanks in advance for the tips.
