Civil 3D Forum
Marked point bug when mirrored in section views
2 REPLIES 2
andre.micka
128 Views, 2 Replies
Hi everybody,
I am stuck with I think is a bug in C3D 2023.2.1.
I have created a simple subbassembly with two lanes and I have added a marked point with a block (footbridge block).
It works fine except I have to mirror one section and the marked point don't follow the mirroring.
I mirror the section view with this option :
When my section is not reverse (sample line in the direction of the alignement)
And when the section is mirrored (sample line in oposite the direction of the alignement)
I don't understand because I have checked the option orient the mark with de view
Is someone have a trick ?
Thank you
Labels (1)
2 REPLIES 2
ecfernandez
in reply to: andre.micka
Hi, I'm not 100% sure, but I think this behavior is due to the block. I mean, you are using a block to represent the complete cross-section you posted. I'd try breaking down the parts of the section to see if the program understands the mirror command. Otherwise, I'd create another block representing the cross-sections at the mirrored stations.
Regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
andre.micka
in reply to: ecfernandez
I tried to split my block in two parts but I have the same issue.
Points are not mirrored in civil 3D when you apply a block on it
Thank you and happy hollidays
Rail Community
