SSM - Create Sheets - Single profile view
jmayo-EE
Mentor Mentor
Message 1 of 10
jmayo-EE
Is it possible to get the Create Sheets command to make a single profile view instead of one per sheet?
John Mayo
Replies (9)
Message 2 of 10
cwr-pae
When creating view frames you have the option to create "Plan and Profile", "Plan Only" and "Profile Only". I have used the 1st two, but not the last. When creating sheets they are placed in the SSM, so I assume (bad idea!) a profile only would go into SSM also.
Message 3 of 10
Joe-Bouza
the profile view is determined by the size and scale of the vport in the prototype. Adjust this and get a single view frame prior to sheets, but it would probably be easier to make the layout and vport in the profile view drawing.
somehow I think I under thought this?
are you looking for one long or just a sing view of a long profile? in create sheets you can control which vframes get created
Joe Bouza
Message 4 of 10
jmayo-EE
Sorry I'm so late geting back to this.
So in other words, it may do something close to what I need but not quite what I need.. 🙂
Joe I think I can take your idea and make a temp sheet set with one vp, copy and paste into the good set whre I replace the multiple profile views with a single one.
THanks folks. Kudos to all.
John Mayo
Message 5 of 10
jmayo-EE
No.
John Mayo
Message 6 of 10
Joe-Bouza
So what exactly are you trying to do? I'm dense that way
Joe Bouza
Message 7 of 10
jmayo-EE
Mapping elc conduit. Miles long. Need to deliver dgn with P&P sheets. Must be a single profile view.
John Mayo
Message 8 of 10
This is strange to me... I have a surface drawing with my profile in it for design. Data reference alignment and PGL into a new drawing to create profile sheets. When I try to create view sheets it fatal errors every time. If I try to create view in my surface drawing I have no issues. An ideas?
Joe
Message 9 of 10
jmayo-EE
NOt really sure but I would just create the reference and use a hidden style. Delete the ref when the sheets are all set if it's not needed.
John Mayo
Message 10 of 10
Scratch that. The file must have been the problem. I was able to do it in a new drawing.
Joe
