SSA 2025 - Status?
SSA 2025 - Status?
fcernst
Mentor Mentor
Message 1 of 18
SSA 2025 - Status?
fcernst
Where is SSA? Is it done?
Fred Ernst, PE
C3D 2026
Ernst Engineering
www.ernstengineering.com
Replies (17)
Message 2 of 18
matt_anderson_pe
Fred -
If you read the release notes for Civil 3D 2025 - I dont think it's being built.
https://help.autodesk.com/view/CIV3D/2025/ENU/?guid=GUID-1777B37B-2DDA-459B-8CDF-AD17B9331C75
Autodesk® Storm and Sanitary Analysis 2024.1 supports the 2025 versions of Civil 3D and AutoCAD Map 3D. For more information, see Release Notes for Autodesk® Storm and Sanitary Analysis 2024.1.
Matthew Anderson, PE
Inundar, LLC
https://wettingthewhetstone.substack.com
Message 3 of 18
jroot
Are we to install Storm and Sanitary Analysis 2024.1 and it will work with 2025?
I might try this if I get time.
Message 4 of 18
fcernst
Hmm...That statement is misleading though..there's no Edit in SSA function on the Analyze tab, which is huge for Workflow implications.
Fred Ernst, PE
C3D 2026
Ernst Engineering
Message 5 of 18
Kevin.Spear
If you have access to the feedback platform, the infrastructure team discussed the drainage analysis workflow roadmap... They have a mostly weekly webinar covering what they are working on. This particular topic occurred at the AU Infrastructure Futures meeting and then posted on the feedback platform.
Kevin
Kevin Spear, PE
Message 6 of 18
matt_anderson_pe
I have not downloaded 2025 yet. I lost my feedback portal access when I left in August.
Inundar, LLC
Message 7 of 18
jroot
@Kevin.Spear what does this mean-are they talking about issuing a 2025 version of SSA?
It would be nice to install it at the same time as I do the 25 C3D installs so I only have to intrude once. I can wait if there is a new one coming out soon.
Message 8 of 18
Kevin.Spear
Based on what I saw in that presentation, it does not appear that a 2025 version of SSA would be coming at all. In fact the workflow shown did not use a file export/import method to analysis and update the model. If you've noticed anything relating to the AEC industry, putting the project in the cloud and working with the data at a granular level is the future. Working the data could be from user input via C3D or via analysis in the cloud.
#waittosee
Kevin
Kevin Spear, PE
Message 9 of 18
fcernst
Thanks Kevin.
Fred
Fred Ernst, PE
C3D 2026
Ernst Engineering
Message 10 of 18
jroot
SSA V2024.1 now shows up in my 2025 Extensions:
Message 11 of 18
giovakasafus
hola a todos, yo instale la actualización del SSA 2024.1, y además en el RIBBON de civil 3D, cree el comando y el boton de acceso a la edición con SSA. Pero no reconoce el comando.
Message 12 of 18
brent
This is actually useful. Not sure that I can say the same thing about the Hydraflow Hydrographs Extension.
Message 13 of 18
tcorey
If Autodesk drops support for SSA, does that mean you'll have to go to InfoDrainage? From free to a couple grand per year, I think.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 14 of 18
fcernst
No, and I haven’t used SSA for quite a while now
Fred Ernst, PE
C3D 2026
Ernst Engineering
Message 15 of 18
Kevin.Spear
The roadmap indicates some functionality in a cloud based analysis. The desktop app, is not cheap, but it is not intended for the development engineer per se. My experience with Infodrainage leads me to believe its intended for H&H watershed folks more than what my corner EV charging station might need to mitigate runoff. 🙂
Kevin
Kevin Spear, PE
Message 16 of 18
matt_anderson_pe
Kevin -
Nope - the development engineer is the right persona, but it originally aimed on the UK persona, and the user concerned with SUDS/BMP/Green Infrastructure.
It combines a simple design tool + SWMM hydraulics.
Inundar, LLC
Message 17 of 18
Kevin.Spear
True - guess I never got to do those combinations of things before. 🙂
Was always hard for me to create a single model that presented data in a way that the local agencies wanted reports for pipe and shed calculations. I often had to define two models so the catchment areas would match the intended reporting. But my shortcomings aside...
Kevin
Kevin Spear, PE
Message 18 of 18
matt_anderson_pe
Two models are a byproduct of how the Corps initially built HEC-1 and HEC-2.  Pulling it all into one model is where we should be.
Inundar, LLC
