Civil 3D Forum
SPLINES! to polylines - alot of them
5 REPLIES 5
33003 Views, 5 Replies
I have recieved a file full of contours that are splines.  I know I can indiviually convert them to plines through the "convert to polyline" command under "splinedit".  I just don't want to do it for all of them.
Any way to highlight all existing contours and convert to plines?
Thanks!
5 REPLIES 5
How about this:
1. Type Pedit
2. Type 'M" for multiple
3. Select all of them
4. Say yes to "Convert lines, arcs, and splines to polylines"
5. Set your precision
This will keep them at elevation as well.
- Mark
Neilw_05
In case you were not aware, in 2013 you can now add splines as breakline data to surfaces if that helps.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
ralstogj
in reply to: Neilw_05
Check out the flatten command limits the introduced vertices.
http://c3dxtreme.blogspot.co.nz/2012/04/civil3d-alignment-from-spline.html
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
worked like a charm.
Thank you, saved a lot of time!
EKey
Try the FLATTEN command. It gives polylines with less number of segments, which makes drawing lighter.
Rail Community
