I created the alignment using the "convert autocad lines/curves" option. labels and tooltips only appear on the first tangent.
not sure whats going on here. any help would be appreciated.
Solved by andrewpuller3811. Go to Solution.
This happens when you have a gap in the alignment.
If you drag the ends of the sections together, the labels will continue.
