Civil 3D Forum
Something is wrong with this alignment
3 REPLIES 3
alexRR6ZB
137 Views, 3 Replies
I created the alignment using the "convert autocad lines/curves" option. labels and tooltips only appear on the first tangent.
not sure whats going on here. any help would be appreciated.
3 REPLIES 3
Jeff_M
in reply to: alexRR6ZB
You probably just need to reverse the direction of the entities and/or be sure the endpoints are coincident.
alexRR6ZB
in reply to: Jeff_M
Thanks for the input Jeff. I tried those things with no luck. I ended up just building it from tangents and free curve fillets.
This happens when you have a gap in the alignment.
If you drag the ends of the sections together, the labels will continue.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Rail Community
