Hey all! I am having an issue with a user that is having very slow performance with something a simple as selecting a polyline. Granted, this is a little bigger drawing, but it does not contain too much along the "civil" aspect (ie corridor, pips, etc.). It is a linework base drawing. When the user tries to select a line or a polyline (2d) there is a 1-5 second lag before they can proceed with anything else. It should be noted that there are very few verticies in the polylines (maybe 10-15 in a pline of any length). To say the least, this is very frustrating. I have tried to get rid of this issue by as best as I can. but to no avail.
Thought?
Thanks in advance.
Is the lag the same on other pc's?
Is the lag the same if a default c3d profile is used?
Has the temp folder been cleaned out recently?
The lag does appear on other computers with the same drawing. It seems to be confined to one or two drawings. The temp file was just cleaned out a few days ago and does not have very much "junk" in it right now (that was the first thing I checked).
What version & service pack?
Has dgn purge been done on the file to remove any dgn linetype data? (this can cause file bloat)
Is lag the same if tested locally & not on a network.
What is the file size?
Slowness can be very difficult to troubleshoot and the more specific information, shared here, the better the chance someone will have a solution.
We are running Civil 2015 with SP2 installed. There was some dgn components that were used in the initial parts of this project, but they exist in this drawing only in the form of an XREF, and have since been removed.
Similar problem here, but it seems to only happen after I have created or selected a hatch.
After that, all selection is very slow.
closing C3D and reopening drawing fixes the problem until I select a hatch again.
