Hi @yemigere, how are you?
In the sight distance dialog box, you can pick a file type and choose the path file for the report. Try to look at the folder or create a new report with the box "Create sight analysis report" checked.
Best regards,
[PT-BR] Se essa postagem foi útil para você, clique em
Curtir! Se a resposta resolveu o seu problema, clique em
Aceitar Solução. [EN-US] If it was helpful to you, click on
Like! If the answer solved your problem, click on
Accept Solution. Matheus Lima Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager |
Instagram @bim_infra |
LinkedIn
