Civil 3D Forum
sight distance analysis report
1 REPLY 1
yemigere
142 Views, 1 Reply
yemigere
hi dears.... I was trying to prepare road marking schedule ....i have done the sight distance analysis but how can i extract the report from civil 3d... thanks in advance!
Labels (1)
1 REPLY 1
Matheus-Lima
in reply to: yemigere
Matheus-Lima
Hi @yemigere, how are you?
In the sight distance dialog box, you can pick a file type and choose the path file for the report. Try to look at the folder or create a new report with the box "Create sight analysis report" checked.
Best regards,
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
Best regards,
Matheus Lima
Rail Community
