SID Transparency - IINSERT Not Working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Ever feel like you're just digging a hole deeper?
I've got SID aerials that are fantastic. I use MAPIINSERT and bring them into my state plane projection dwt all the time. And I can adjust the transparency of them, which is sometimes pretty important.
There's a new projection in my area from the DOT. I've got dwt's that are set to that projection, but the SIDs are still state plane.
MAPIINSERT does not seem to let me edit the coordinate system and, using that command, the images come in somewhere in the Beauford Sea.
I have 2019 Raster Tools (after I pointed my Support path to the folder) and there's a button there for IINSERT. That allows me to edit the coordinates. (Which I don't think I could do in 2017.) But when I attempt to use this, C3D freezes for at least as long as it takes to get a cup of coffee, which is my metric for "broke". (The SID images appear in about a second using MAPIINSERT.)
I can Connect to Data (not sure actual command name) using the Task Pane MAPWSPACE...Actually, the process that Allen describes here: https://forums.autodesk.com/t5/civil-3d-forum/insert-mr-sid-images/m-p/5732344#M279298.
But, while I can resample the SID by zooming to the area I want and right-clicking in the Task Pane and pick Resample Raster, I see no option for adjusting the image's transparency.
I can put the image on a layer and set the layer's transparency. This actually works, but although I have the Transparency set to Show in model space, the image does not appear to be a % transparent until I plot. I do a lot of screenshots, so this isn't the best scenario.
This dilemma is somewhat due, by the way, to that app Halo Text not having 2019 support. That's a great app. I wouldn't need image transparency so much if that worked.
So, is there any solution to this? I want a wysiwyg model space with a % transparent SID image georeferenced to a different projection than native to the image. I'd also be interested in getting the actual image into C3D and not the data connection version of the image. I think, if IINSERT worked, I'd be okay. But it don't.
