Civil 3D Forum
SID Images transparancy
9 REPLIES 9
Message 1 of 10
cneely
1344 Views, 9 Replies
We are using SID aerials and would like to make them transparent. There is no setting we can find to do this. Anyone have experience w/ this format and know how to fade them back? Thanks.
AEC Collection 2022
WIN 10 PRO
Dell 3650, Intel i9-11900k @ 3.50GHz, 64 GB
NVIDIA QUADRO RTX 4000
http://www.cobbfendley.com
9 REPLIES 9
Message 2 of 10
jmayo-EE
in reply to: cneely
Set a transparency value on the sid's layer. Make sure when you plot the plot dialog has Plot Transparency checked.
John Mayo
Message 3 of 10
cneely
in reply to: jmayo-EE
We used MAPWSPACE to insert them so there isnt really a layer that they are on. We were having issues w/a traditional raster insert due to conflicts w/ projections and that is what worked so we went with it.
AEC Collection 2022
WIN 10 PRO
Message 4 of 10
jmayo-EE
in reply to: cneely
Keep the images in a separate file with no other data. Xref into the working file and no issues. Bonuses - you have better perrformance with an xref and can plot with transparency. 🙂
John Mayo
Message 5 of 10
cneely
That has potential. Can I fade just one xref? We have multiple references in that dwg.
AEC Collection 2022
WIN 10 PRO
Message 6 of 10
jmayo-EE
in reply to: cneely
I would try placing the xref on one unique layer and assign the transparancy to that layer. See if it goes. I normally only have a few layers with images so I set the value on each IMG layer.
John Mayo
Message 7 of 10
Jay_B
in reply to: cneely
If it's just the Image you're looking to adjust/fade, then create a separate xref as John mentioned & then the image can be adjusted.
The IMAGEADJUST command must be applied within the xref dwg file containing the SID images.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 8 of 10
cneely
That didnt do it. When I xref the drawing w/ the aerial nothing shows up. Something to do w/ it being attached as data instead of inserted as a raster?
AEC Collection 2022
WIN 10 PRO
Message 9 of 10
jmayo-EE
in reply to: cneely
Your still using FDO (mapwspace) to insert the images. You need to use MAPIINSERT or Raster Design's IInsert. Yes two i's, for MapImageInsert or ImageInsert. These commands will geolocate the raster files to the dwg and insert them as raster data. Set the dwg coordinate system first.
John Mayo
Message 10 of 10
darrell.kennedy
Works perfectly, thanks!
Rail Community
