Showing multiple Live Section views in paper space at once
sgleadleD3EMJ
sgleadleD3EMJ
I'm trying to compare my point cloud data to my design model. So I'm using live sections to cut cross sections, but I would like to plot more than one section view at a time, which I cant think of a work around to the fact that I believe you can only have one active section view at a time. Maybe someone else can?
I have a video below showing what I mean a bit better.
SoaresASBCAD
sgleadleD3EMJ
Section views are different vs section planes. This technique wont work here.
brian.strandberg
If you have your point cloud as a surface I would do a TIN Volume surface and create a heat map of the differences.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Shea_G
I need to be able to compare vertical faces as well
