Civil 3D Forum
SHOW Boundary Issue
3 REPLIES 3
jessekenniston5NPDB
228 Views, 3 Replies
SHOW Boundary Issue
Hi there,
See below. I created a surface from 4 feature lines, however I only want the surface to show up inside of the feature line shapes. I'm trying to use 4 SHOW boundaries to complete this. I've tried it with and without the non-destructive option checked with no luck. For reference, I've got about 100 feature lines that I'd like to put into a single surface, this is just a sample. Any help would be appreciated.
Jesse
3 REPLIES 3
I'll add to this that using the HIDE boundary on all 4 feature line shapes seems to hide everything outside of the shapes, which is the opposite of what I'm trying to do.
Try using your overall outer boundary (the dashed line) as a "Hide" boundary. Then use your other 4 areas as a "show" boundary. In theory, the hide boundary will hide the entire surface, then the individual show boundaries will show the surface in that particular area.
Civil 3d 2023
Processor Intel i7-13700K Sixteen Core Enhanced Performance Processor
System Memory 32GB DDR5-4800 MHz (2 - 16GB DIMMS)
M.2 Storage 500GB SSD NVMe/PCIe 4.0 M.2 Drive Expansion Card Slot(s)
NVIDIA RTX A2000 12GB
Operating System Microsoft Windows 10 Professional Edition
System type 64-bit operating system, x64-based processor
Worked like a charm! You saved me a weekend worth of work. Thank you!
Rail Community
