Sheet Set Manager for Web - STB file not being utilized
matt.whislerCMJPM
Message 1 of 8
matt.whislerCMJPM
We are using Civil 3D 2023 with project located on the Autodesk Construction Cloud. When publishing to PDF though SSM for Web, it is not utilizing our STB file. We've had no issue for years with older SSM. The company STB is saved on a server. We also saved a copy in an ACC docs folder in case it would read it there. We have also tried adding the STB path to the Plot Style Search Path on all installed Autodesk products. In addition, we have added the STB to the  web.autocad.com support files.
Does anyone have any suggestions for getting Sheet Set Manager for Web to utilize our STB file? TIA.
Replies (7)
Message 2 of 8
lim.wendy
Hi Matt,
Thank you for reaching out regarding the issue you're experiencing with Sheet Set Manager for Web not utilizing your STB file. I see you are visiting as a new member of the Civil 3D forum. Welcome to the Autodesk Community!
Given the complexity of the issue you're facing, it appears that further troubleshooting may be necessary to pinpoint the exact cause of the problem. While I'm here to provide assistance where I can, I highly recommend reaching out to our dedicated Support Team for a more thorough investigation. They have the expertise and resources to delve deeper into the technicalities and provide tailored solutions to address your specific situation.
In the meantime, @C3D_TomR may offer valuable insights or suggestions based on his experience with similar issues.
  1. Visit the 'Contact Support' page at https://www.autodesk.com/support/contact-support.
  2. Once there, please sign in to your account
  3. Select the 'Using and troubleshooting my software' option.
  4. Next, provide a detailed description of your issue or question.
  5. Click on 'See options,' and you will be presented with your subscription contact choices. You can either click 'Live Chat' to chat with an Autodesk support specialist or click 'Create a case' to send your question via email.
Remember to mark your posts as having an "Accepted Solution" if a solution is found as it helps other forum users with the same issue – so don't be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems. . You could unmark the post as an accepted solution if the solution did not work. Click the ellipsis menu  > Not the Solution to cancel an accepted answer.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 3 of 8
Adam_Farnsworth2
Do you have your STB saved in a Support folder location in your ACC folder structure, and is the Support file path pathed correctly?
Message 4 of 8
Gerald_Lambayan
Is there already a solution for this one? I am currently experiencing the same issue.
Message 5 of 8
Adam_Farnsworth2
The best solution I've found for publishing is to set the SSMDETECTMODE to 0 and using the old SSM, unfortunately. SSMFW isn't quite ready for production, it seems.
Message 6 of 8
Gerald_Lambayan
Found the solution:
I have been in the same situation with the poster.
Using C3D 2023 or maybe this is also applicable to latest versions.
1. proceed to https://web.autocad.com/. log in your credentials.
2. when logged in, on the left side of the screen, select "+Add Storage Source."
3. select and add the storage source, in my case I added the Autodesk Docs.
4. after clicking add, proceed back to left side of the screen and select "Manage Support Files".
5. once inside, under the "Manage Support Files" window, click on the source and select your project.
6. Next click the "Plot Styles" and upload your CTB/STB file. Then click done.
You can now use your Sheet Set / .dst file that you have arrange and at the same time it utilize the correct ctb/stb file.
Make sure all users has access of the BIM360 or ACC of the specific project and have applied this workflow so that they can use the dst file with the correct ctb/stb file.
Message 7 of 8
brad_kantherDM5YB
@Gerald_Lambayan i just tried the above... and the "Manage Support Files" option is no longer there! Im guessing this has to be done via ssm support paths as per @Adam_Farnsworth2 suggestion.. But as far as i can tell its not even detecting the CTB/STB via this path
Message 8 of 8
ceethreedee.com
This is now done by project, although supposedly it is possible to do it for your whole ACC Hub..
Read the help guide here
In a nut shell though, its still done via Autocad Web "web.autocad.com"
Add your project from Autodesk Docs in..
Then hit the three dots... and choose "Project Support Files"
There is a popup up the top that will ask you if you want to setup your "Connected Support Files"
This will create a folder at the root of your "Project Files" directory on ACC called Autodesk.Support.
Its seem to be possible to add other folders.. By going back into the Project Support Files . Its add two new options up the top.
Finally i can now see my plotstyles showing up in the project support files sections
Despite all this .... IT STILL DOESNT FIND THE PLOTSTYLES!!!!
If anyone knows what i'm doing wrong... please tell me!!
all this stuff is supposed to be black in PDF!!
Civil 3D 2025 / Infraworks 2025
Win 10 -DELL Precision Notebook 7680
Want FREE TOOLS! Come get my free productivity tools for civil 3d from the appstore here Ceethreedee tools
Or from my website below!
https://ceethreedee.com/ceethreedee-tools
