shape style for material section does not work fine
joantopo
Mentor Mentor
joantopo
Hi.
I noticed this 3 or 5 years ago and currently it seems that is not solved by Autodesk team.
Calculated material is from 2 surface sections (above yellow surface section and below orange surface section)
As you can see, this material style has a pattern associated in its shape style with ANSI31 pattern in light orange.
However if the section view has another surface sections and they are inside or partially inside of the result area, pattern also includes their lines:
Look at if we  put this material to the background, surface sections are on:
So if Sample Lines have another Surface sections (even if they don´t participate to calculate this material), then hatch is wrong. If hatch is SOLID you can also see this lines if you select the material.
This is very annoying specially when we convert to ACAD dwg and hatch boundaries are not correct.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
joantopo
Any solution?
