Message 1 of 9
So I'm trying to use the grading optimization tool offered by Civil 3D to make my life easier. Using it requires an EG/TIN surface to grade on. Problem is, the site given to us is just a sketch. I manually traced the existing contour lines using polylines and assigned elevations to them (by the way, does anyone know how to display the elevations in ft, not inches?). Then, I created an EG/TIN surface using the new polylines and set a boundary. The grading tool worked, but came out to be a mess (See below). I'm not too familiar with Grading Optimization/ Surfaces, so any help is appreciated. Thanks!
