Setting up an EG/TIN Surface to use Grading Optimization Tool
aa6673
Message 1 of 9
aa6673
So I'm trying to use the grading optimization tool offered by Civil 3D to make my life easier. Using it requires an EG/TIN surface to grade on. Problem is, the site given to us is just a sketch. I manually traced the existing contour lines using polylines and assigned elevations to them (by the way, does anyone know how to display the elevations in ft, not inches?). Then, I created an EG/TIN surface using the new polylines and set a boundary. The grading tool worked, but came out to be a mess (See below). I'm not too familiar with Grading Optimization/ Surfaces, so any help is appreciated. Thanks!
Replies (8)
Message 2 of 9
Pointdump
Hi @aa6673,
"...does anyone know how to display the elevations in ft, not inches?"
Look in Drawing Settings >> Ambient Settings.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 9
aa6673
Thanks!
Message 4 of 9
Pointdump
@aa6673,
Changing Dimension Units to Feet just now had no effect whatsoever, and I can't find any other Inch unit settings in Ambient Settings. I'm baffled, and I'm hoping someone will chime in with a solution.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 9
rl_jackson
If you go to the UNITS command, currently the drawing is set to use Architectural Units, this should be changed to decimal. While there change insertion units to UNITLESS. HTH
Rick Jackson
Survey CAD Technician VI
Message 6 of 9
Pointdump
Rick,
I can't believe I missed that. I checked Drawing Settings >> Units and Zone and saw that Drawing Units were set to Feet, but I didn't check UNITS. Good catch.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 9
aa6673
So I tried both your solutions and my elevation values are still appearing in inches. Is there something else I'm missing?
Message 8 of 9
Pointdump
@aa6673,
Which elevation values? Screen shot please.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 9
aa6673
Apologies! I assumed my elevations would correct itself to ft after inputting the elevations in inches. I had to manually change each elevation after adjusting my units. Now it looks much better!
Thank you all!
