Selectable and searchable text in a PDF
07:31 AM
- Mute
- Permalink
- Report
Hi all,
I'm using an Autocad Civil3d 2014 version. When I create a drawing and I print it in pdf format, then I am not able to select any text that was inside the viewport.
I already found this solution on the forum: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
It seems that the problem is related to the variable "PDFTEXTRENDER", which value should be 1.
In my Autocad version, if I type PDFTEXTRENDER in the command line this message appears:
Unknown command "PDFTEXTRENDER"
Does anyone find this kind of issue?
Thanks.
