Civil 3D Forum
Select all CTRL A in toolspace expands everything. How to collapse it all?
5 REPLIES 5
RobertEVs
228 Views, 5 Replies
RobertEVs
Sometimes I make a mistake when I want to edit JUST multiple surface styles in my toolspace I miss and instead select (CTRL>A) everything in the Active Drawing View. Upon doing this C3D expands every single thing in the toolspace. From here I usually just start hitting the minuses to shorten it all back up.
Does anyone know how to minimize the categories in the toolspace? Same way I can expand and collapse in the corridor properties window.
Labels (1)
5 REPLIES 5
tcorey
in reply to: RobertEVs
tcorey
On Prospector, switch to Master View or to Active Drawing View and then back to what you were using. This will de-select everything and collapse the drawing.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Tim Corey
Redding, CA
RobertEVs
in reply to: tcorey
RobertEVs
I was hoping that would work but alas, No. Still expanded. As long as I stay in master view then that works. I have to close out of the drawing and re-open to get the list collapsed.
tcorey
tcorey
My bad. Like you said, it only collapses when you go to Master View. Bummer.
Tim Corey
Redding, CA
Tim Corey
Redding, CA
RobertEVs
in reply to: tcorey
RobertEVs
Generally, not a problem. I minus click the expansions and go about work. This one particular dwg has several, and I mean several lot gradings done individually turned into small independent surfaces. A CTRL>A on the toolbar makes for a long expanded lists.
user181
user181
Try CTRL + the Left Arrow Key
Rail Community
