Civil 3D Forum
Section Views
1 REPLY 1
352 Views, 1 Reply
Section Views
i'm having several issues in this model and i'm not able to find the way to solve them.
*First of all the one marked on green this line apears in all section views. In the assembly I don't dee the element wich is generating that line in order to eliminate it.
*Second the Red One in some Sections the assembly doesn't reach the target surface.
*Third the pink In Some Section the assembly is placed in a place but the polygon for computing material is displaced.
Tags (2)
Labels (2)
1 REPLY 1
M_Obradovic
Hi  estudioihs
In order to solve second and third issue just change corridor frequencies each 10 m, Because your sample lines every 50m don't overlap with corridor frequencies.
For the first issue I just change daylight subassembly and use generic link LinkSlopeToSurface and some strange part in center disappeared. I also attach drawing with changes.
Hope this Help
Rail Community
