Section View Quantity Takeoff Table vs. Material Table
camden.n.dean
camden.n.dean
Nooby question today.
If you dive into the drawing settings -> object layers tab, you can see all of the objects that C3D can make. While going through these, I found two things that I thought were the same object.
1. the Material Table (related to material sections), and
2. the Section View QTO Table
Would someone please explain to me the difference in these two objects? I'm sure it's obvious to a more experienced user.
-Camden
lim.wendy
Hi Camden,
Thanks for reaching out to the forum. I can understand the potential confusion between these two tables. I suggest reviewing this thread that explains the Section View Quantity Takeoff Table, along with this article that discusses the Material Tables.
I hope that helps.
Let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
camden.n.dean
Thanks again @lim.wendy ! You're great. I knew this had to be pretty simple, but I had never seen the Material Tables before so I was needing some guidance from an expert. Thanks for the great help!
-Camden
