Section view- adjust center axis
nabilhoren
nabilhoren
Hi everyone,
I hope you are doing well. I would like to change the center axis to a desired length in a section view in Civil 3D. Where can I edit this, and which style should I modify?
Best regards
ecfernandez
Hi @nabilhoren, thanks for posting your question. To understand better the situation. Do you want to shift it 1m to the left, up, or down?
1. To shift 1m to the left. Draw a twin alignment that runs parallel to your design alignment. Then create the sample line based on that alignment and finally sample everything (corridor, surfaces, and any other stuff you had in your previous cross section)
2. To shift it up/down. I think this translates in adjusting the layout profile, or the section view grid. You can do that in the section view
Let me know your thoughts!
Best regards.
Camilo Fernández
P.Eng | Transportation
LinkedIn
nabilhoren
Hi Camilo, thank you for your replay. I want to shift it up/down. Is that possible to write down the steps.
bhavani_sankuratri
Hi @nabilhoren ,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Bhavani Sankuratri | Community Manager
igi_pop
Hey there!
Your section view is shallow. The axis is as long as your section view height. So, if the view is 5m - the axis will be 5m. It cannot be independently set.
And that setting is done PER-VIEW. Other settings are a bit tricky, like the "section height" when creating multiple section views, cause they tie to the major grid step (if i'm not mistaken).
Iggy
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
nabilhoren
Thank you. I already found a solution.
nabilhoren
Thank you
