Civil 3D Forum
Section Points Report
2 REPLIES 2
babulalsahu
156 Views, 2 Replies
I tried to extract Cross Section Points Report from a Corridor. I need the data (x,y,z) at Geometry Points, Start, End Stations and 10m intervals. But the in-built report style gives data at required 10m intervals only not at the Geometry points , Start, End stations.
Is there any workaround to get the report as desired x,y,z data for the points "Geometry, Start, End Stations" as well as 10m interval.
Regards
Babulal sahu
2 REPLIES 2
ecfernandez
in reply to: babulalsahu
Hi @babulalsahu, my suggestion would be that you use this report
Before you execute the report, make sure you have assigned the frequency options of the corridor properly here:
This is how often Civil 3D will apply your assembly along the baseline of the corridor. Make sure you put 10m and "Yes" to the options of your preference (horizontal geometry points, superelevation critical points...). Points will be reported where the assembly is applied according to the frequency. This way, you can get the coordinates of all the points you mention are missing (start, end, geometry points)
I hope this helps. Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
babulalsahu
in reply to: ecfernandez
Dear Sir
Thanks a lot for your kind effort. With your notes I am able to get the desried report at Horizontal Points stations.
I have used the option ;  Miscellaneous Utilities-> Reports-> Corridor-Corridor Point Report
But I am not able to get the data at the Start & End of the base line.
Request you to please check wether, you are able to get the data at start & End points by using the above option.
Regards
Babulal Sahu
Rail Community
