- Mute
- Permalink
- Report
I was trying to create a custom linetype using MKLTYPE, but seem to be having issues with the scaling. All the videos or tutorials I have found so far don't really seem to discuss how the linetype should be scaled during creation depending on how large/small the viewport you are trying to display the linetype in.
For example, if I am creating a linetype that is to be displayed in a viewport with a scale of 1"=500', and draw my custom linetype to an overall length of 1 unit in model space how will the linetype be displayed. So, far each time I try to do this I can't get my linetype to display correctly without having to adjust the scale in properties to usually a really small value like 0.01 just to get the graphics in the linetype to display correctly as opposed to just a solid line.
Not sure if this is the correct question to ask but here it goes... When creating a custom linetype does the length of your linetype have to be adjusted in accordance with the scale of the viewport you are going to display it in? Thanks in advance for any insight/help.
