Hi, all. Here's my problem, and I'm hoping someone has some insight. I created a basin from a grading group and added/modified points for the emergency spillway. It all looks fine except at one point. The program is following a different tin line to draw the contour. I tried swapping the edge, but it just made it look worse because it cut across the dam perpendicular at the left point (in the attached image) and continued a single line to the bottom point. My elevations are all correct (the points are spot elevation labels, so I know the surface is at the correct elevation). I tried making a breakline and adding it, but that didn't help either. Does anyone know how to fix this or will I just have to use plines for actual printing? Thanks!
