Scalebar different with PUBLISH/PLOT command
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, Im having issues with the integrated scalebar "scalebar1_metric" when using PUBLISH command.
When creating PDF using PUBLISH, the scalebars in paper space randomly changes size/position on some layouts.
This is seemingly random, when creating the same PDF using the same settings, on same device in same session with PUBLISH again, it may affect different layouts in different sizes. When creating single PDF using PLOT command, this doesnt happen, everythings fine. However, I need to use PUBLISH since there are many layouts.
Any idea what could cause this? Wheres the difference between PUBLISH/PLOT regarding the scalebar block?
AutoCAD Civil 3D 2024
Drawing Units are meters, Drawing scale 1:1000
Block Units (scalebar1_metric) are centimeter, scale varies with layouts
Scalebar is associated to respective View Port, which is created using polyline
PUBLISH/PLOT use same PDF preset and Page setup
Any helps much appreciated 😃
