Civil 3D Forum
scale tinsurface without scaling elevation
7 REPLIES 7
Message 1 of 8
wang890
3285 Views, 7 Replies
a while ago i asked how not to scale contours, aeccpoints and acadpoints and end up i made a program to reset the Z value in vb.net.
but, now i need to scale a tin surface from UTM to plant coordinate system. which i don't want the elvation to change at all. as you all know autocad scale command scale xyz unlike ustn which you have a choice.
i do have a few options to deal with this but easiest way would be tell the software not to scale z. anybody knows how to do that?
i am a multi solution guy so here is what i will do if there is no easier way:
1. show points and export to acad, then run my program to scale the points and polyline breaklines then rebuild surface
2. scale the tin surface and create a style and set the triangulation exaggeration to 1/scale factor, easiest way but will mess one style up. i guess that's ok. but still please please modify the scale command so user have an option to scale xy only. scaling z is pretty rare in civil engineering. wanted for 3d people i understand.
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
7 REPLIES 7
Message 2 of 8
tcorey
in reply to: wang890
I have a way to do this.
Create a block using the surface as your selection set.
Insert that block, applying the x and y scale factors you need, but leaving the z scale at 1.
Explode the block.
Voila!
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 8
Pointdump
in reply to: tcorey
Tim, that's a great idea!
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 4 of 8
wang890
in reply to: Pointdump
very good idea. works fine.
thanks a lot.
Stantec
Message 5 of 8
How can I now explode that block?
Cheers
Allan
Message 6 of 8
tcorey
Use the Explode command.
Be sure that during the creation of the block, you check the box to Allow Exploding.
Tim Corey
Redding, CA
Message 7 of 8
sboon
in reply to: tcorey
I'm guessing that the new surface definition would include all of the original point groups, breaklines etc.  What happens if you rebuild it?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 8 of 8
in reply to: tcorey
Thank you for this. I am having a similar issue with scaling elevations and this simple solution has saved me tons of time re-elevating.
Rail Community
