Civil 3D Forum
running the audit command corrupts my feature lines
13 REPLIES 13
Message 1 of 14
CFernets_IEAC
743 Views, 13 Replies
running the audit command deletes the feature line inserted elevations
13 REPLIES 13
Message 2 of 14
troma
in reply to: CFernets_IEAC
What version of C3D are you running?
Are your service packs up to date?
Mark Green
Working on Civil 3D in Canada
Message 3 of 14
CFernets_IEAC
in reply to: troma
civil 3d 2016.
All service packs are up to date.
Message 4 of 14
i found the hotfix link and followed the instructions... works prefect. tks
Message 5 of 14
CFernets_IEAC
in reply to: troma
found the hotfix link.. followed the instructions... all good. cheers!
Message 6 of 14
Hi, I am having the same problem, do you know which Hotfix addresses this?
Message 7 of 14
vinceroux
Hot fix 3 is supposed to fix the original feature line issue.
A bug still exists despite this hotfix. I've already gone through the support team and was told the dev team is looking into it.
Auditing (with error correction) non-closed feature lines with grading objects will explode those feature lines and grading objects. This does not occur with closed feature lines.
Message 8 of 14
troma
in reply to: vinceroux
What version are you running?
Are feature lines without a grading affected in any way?
Mark Green
Message 9 of 14
Jay_B
I have not seen the Hotfix referred to as Hotfix 3?
The 2016 Feature Line Hotfix can be found here.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 10 of 14
vinceroux
in reply to: Jay_B
I'm sorry, I meant the feature line hotfix, not hotfix 3. Hotfix 3 exists but is unrelated.
https://knowledge.autodesk.com/support/autocad-civil-3d/downloads/caas/downloads/content/autodesk-C2...
The problem I have encountered applies to the grading objects attached to non-closed feature lines. The grading object breaks into static feature lines. Feature lines on their own are not affected (from what I can tell).
I'm running civil 3d 2016, service pack 2, all the updates/hotfixes.
Message 11 of 14
vinceroux
I see hotfix 4 has been released, and no mention of this problem being fixed...
Message 12 of 14
Am I missing HF 4 in the download list?
Message 13 of 14
Jeff_M
bscott, it should appear in the Autodesk Desktop App. I saw it, downloaded it, installed...and was greeted with a message that my install is already up to date, no need for the HF. But, as far as I know, I have not ever applied this hotfix (it was released today), nor did I do any Beta testing for it. <shrug>
Message 14 of 14
vinceroux
in reply to: Jeff_M
Indeed, it appeared in the new autodesk desktop app. But like I said, didn't help the broken grading object bug that I described earlier in this thread.
Rail Community
