Message 1 of 14
Rotating entire project changes Surface and Point elevations
02:51 PM
- Mute
- Permalink
- Report
Here my situation.
I have a project that was originally surveyed using the north zone. The client wants the coordinates system for the south zone. (North south line splits the town).
When I try to rotated the entire project based on angle the Surveyor provided it changes the survey point elev's and the surface elevation.
The coordinates for the points change to the correct zone as needed.
I have made sure the "Allow checked in points to be modified" is set to true. I am using the standard autocad rotate command from tool bars. Is there a different way to rotate that doesn't change the elevations?
What am I missing?
2015 in use
Dave Z.
