Road Corridor Slope (daylight) hatch / style
jimgi78okt
jimgi78okt
Hi to everyone. I am wondering if there is a simple way to achieve a style for presenting the daylight at an embankment as in the picture below
I have considered to create a custom linetype, which i could apply from the code set style. The problem with that is that the embankment height is varying, so this can not serve my scope. Is there any other way? Maybe through hatch or something else?
Matheus-Lima
Hey @jimgi78okt!
Have you tried the slope pattern from the corridor properties? You can add these patterns and apply different styles, check it out: https://www.youtube.com/watch?v=LzN0lPoawcA.
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
jimgi78okt
Matheus i have not checked it. Still learning! As i saw the video this must be the answer! Thanks a lot!
