Reverse Alignment Direction
LarryS23
LarryS23
How come when I reverse the direction of an alignment instead of starting from 0 it starts from -0+14 and ends at 0? Help
tcorey
Change the starting station after reversing. Information tab of Alignment Properties.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Jeew-m
How did you reverse the alignment.
1. Use Reverse Alignment option in Civil 3D.
2. By changing the reference point of Alignment
If you use method 1 it will come as reversed stations. 0+000 to 0+014
But if you use method 2 you will get it as -0+014 to 0+000
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
LarryS23
So this is a curb return alignment. I tried reversing the alignment and then I used station offset label to confirm the process, but it does not do anything.
