Can't open CSV file. Says "No point file format match found"
esaidesignco
Observer Observer
esaidesignco
Observer
Observer
Hi everyone,
I'm new to Civil, and I can't seem to figure out how to configure my CSV file to open. Anyone else able to import the file?
rkmcswain
Reduce that file to the Northing, Easting, Elevation columns for now (delete the other columns), and try again with a matching format. Then add the desired columns back in, one at a time, and test each step. You may have to create a new format inside of Civil 3D depending on what columns you want to ingest.
R.K. McSwain     | CADpanacea | on twitter
Pointdump
Hi Melvin,
That's not a "normal" point file. To import that CSV you'd have to add a lot of UDP's(User Defined Properties). Or you'd need to turn it into a shapefile.
I lost count of how many columns there are in that CSV. If you want to use it to create points in Civil 3D, I'd delete most of the columns in Excel, then go from there. What data in that file do you need?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Jeew-m
Open a new excel sheet.
Copy the first 4 columns of your csv to that excel (Point name, Northing, Easting, Elevation)
Then copy the points name data and paste it to a fifth column after elevation column.
Now replace the point names of your first column with point number like 1,2,3 etc.
Now save the excel as csv file and import it to Civil 3D with the point file format PNEZD.
make sure when you import point your excel file is closed.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Pointdump
Melvin,
I created a Shapefile from your CSV file. Drag-n-Drop it into your drawing.
Dave
Dave Stoll
Las Vegas, Nevada
