Reverse a Feature LIne Curve
F.Camargo
F.Camargo
Hi guys,
How are you?
I'm trying to reverse a feature line curve. How Can I do that?
I've already changed the radius and I'd like to put it in the green curve.
Replies (11)
JustOpie
I'm interested in knowing that, too.
I typically trim that curve out of the figure. Then draw the new curve in as a polyline for converting into a feature line.
If you are dealing with elevations, I would place the converted polyline on a separate site and then adjust the ends of the curve to the correct elevations, before joining with the original feature line.
F.Camargo
The parcels was changed and I need to updated the old one. I don't wanna to create a new one to fix it.
I need to convert curve to line too.
doni49
@F.Camargo wrote:
Hi guys,
How are you?
It sounds like you want the blue curve to look like the GREEN curve.  Select the FL, then Pick "Edit Curve" -- just before the dialog opens, you should see an option to DELETE the curve (at the command line).  After you've deleted the curve, the tangents will be joined and you can use the fillet command to put the curve back in there.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
F.Camargo
@doni49 wrote:
@F.Camargo wrote:
Hi guys,
How are you?
Hi Don,
I couldn't delete the curve as you said. But I've notice in edit curve dialog, maintain tangency worked fine for me.
But When I press OK isn't working as I wish.
See the file attached, please.
test.dwg
Fabricio
rl_jackson
I'm think you drew the line in a clockwise direction, and curves in ACAD are created in the opposite direction, bet if you create it in a counter-clockwise direction, opposite of what you did it will create the curve as expected.
Rick Jackson
Survey CAD Technician VI
F.Camargo
So, Do I have to delete the curve and insert a new PI and use fillet FL the right direction??
doni49
"I couldn't delete the curve as you said."
When you initiate the EDIT CURVE command (before the dialog pictured in your screenshot above opens), look at the command line. You'll see two options and one of them is DELETE. Press D and the curve will be deleted.
Don Ireland
F.Camargo
It isn't working for that drawing. I've tried it.
Pointdump
Fabricio,
1. Maintain Tangency.
2. Type in "6" for radius.
That worked for me.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Pointdump
Fabricio,
I was having inconsistent results, so I made a Screencast.
Dave
Dave Stoll
Las Vegas, Nevada
F.Camargo
@Pointdump wrote:
Fabricio,
Dave
Wow,
Excellent result my friend Dave!!!
It is just like I wanted to do. Thank you very much 🙂
I think that post will help a lot of people. Well Done!
Fabricio
