Representing curb in surface using breaklines
jhannonZKZH7
394 Vistas
2 Respuestas
Mensaje 1 de 3
jhannonZKZH7
Hello!
I am trying to model a curb in my surface (6in height, 8in width) using breaklines so it is properly displayed in my surface profile. It works fine at the feature lines, but between the two sides of the curb it dips down to the ground elevation again. I want to make it so that the entire area between the lines representing the edge of the curb is at the constant 6in above the ground elevation. How would I go about this?
Thanks.
0 Me gusta
Soluciones aceptadas (1)
395 Vistas
2 Respuestas
Respuestas (2)
Mensaje 2 de 3
tcorey
Can you post your drawing?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Mensaje 3 de 3
jhannonZKZH7
Solución aceptada
Thank you for your response! I figured out how to do it using the "stepped offset" command and setting a feature line for both the bottom and top of the curb.
0 Me gusta
