Removing Vertices in 2D Polylines
bforr
Message 1 of 9
bforr
C3D 2018
It seems in the past versions when I pick a pline and grip a vertex and right click I would get an option box to remove vertex and could repeat with multiple grips.  Now it only allows me to remove one vertex and the option box doesn't appear for the next vertex.  I have to esc, pick the pline again and remove-esc, pick, remove-esc, pick, remove continuing forever.  Is there a setting to fix that?
Replies (8)
Message 2 of 9
KMercier_C3D
You are right that is very clunky.
Instead when you select the polyline, go to the Modify ribbon and select Delete PI, this will allow you to continuously select vertices to delete (likewise you can Insert PI to add vertices onto the polyline).
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Message 3 of 9
bforr
Nice.  Didn't realize some of those functions applied to plines.  Use them all the time with feature lines.  thanks KMercier.
Message 4 of 9
MMcCall402
You can also hover your mouse over the vertex, or midpoint, and a menu will pop up for editing that point. You can either choose a selection from the menu or press a letter corresponding to a selection.  (example: R = remove, C = curve, A = add)  If it stops responding just escape and re-select the line.  (its a timing thing, if you make a selection before the menu appears it gets lost)
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Message 5 of 9
wlewis
Message 6 of 9
bforr
hmmm i don't have Map installed.  Thanks.
Message 7 of 9
wlewis
Neither do I....
It worked for my install of Civil 3D 2018
Message 8 of 9
bforr
ah.  before I responded I had tried to install it.  It seemed to hang up in the middle of the install so I cancelled thinking I needed Map.  Will try again.
Message 9 of 9
bforr
Well, slacker here just installed the Map hotfix and it did seem to stall but did continue and complete the install.  It worked.  Now my menus appear when hovering over vertex until I cancel the command.  Thanks.
