Remove .DST's from Recent Documents list
Jeff_M
Consultant Consultant
Message 1 of 68
Jeff_M
Attached is a zip file with a standalone program to aid in cleaning up the Recent Documents list for all flavors of AutoCAD, 2009-2013.
It's pretty self explanatory, just be sure to run it with no sessions of AutoCAD, or vertical products, running. It should refuse to run if it sees any Acad.exe application in the running tasks list. Once the dialog opens it will show you all of the Autocad related products you have installed, select one and it will fill in the first list of recent documents. Then select a profile for that product and the second list will populate with the SSM related recent documents saved for that profile. You can then select any item from either list, if the same DST filename exists in both lists it will automatically select them both. Use the standard selection methods to select more than one (shift-click, control-click, window).
Be sure to Unblock, if needed, the zip file before extracting the exe file. (Check the file properties)
If you find it useful, or if you have any problems with this, please let me know at jeffm AT quuxsoft DOT com
Replies (67)
Message 41 of 68
ceethreedee.com
So comforting... i cant wait to switch now..
Civil 3D 2025 / Infraworks 2025
Win 10 -DELL Precision Notebook 7680
Want FREE TOOLS! Come get my free productivity tools for civil 3d from the appstore here Ceethreedee tools
Or from my website below!
https://ceethreedee.com/ceethreedee-tools
Message 42 of 68
ceethreedee.com
Jeff
You just solved two problems for me.
thanks
Message 43 of 68
d0gMa
You are a beautiful beautiful person and I could just kiss you! This program has just fixed the problem booting with SSM when I move .dst files, thank you!
Message 44 of 68
Why you people go so far ...
Just a .reg works perfectly !
1. Open a new text document
2. Copy paste this:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R20.0\ACAD-8001:409\Recent File List\]
(If you use an older version of AutoCAD just change the version from R20.0 to R18.0 for example for version 2012. If you use AutoCAD MAP maybe you have to change just the folder name AutoCAD to AutoCAD MAP to clear all the history of recent file. I have tried this with AutoCAD 2015 and it works perfectly!)
3. Change the extension form .txt to .reg
4. Just say OK
P.S If you wanna clear the adobe Reader or Acrobat history of recent file same philosophy! Or just like a lawyer will say Mutatis mutandis ...
1. Copy paste this:
[-HKEY_CURRENT_USER\Software\Adobe\Adobe Acrobat\11.0\AVGeneral\cRecentFiles]
[-HKEY_CURRENT_USER\Software\Adobe\Acrobat Reader\11.0\AVGeneral\cRecentFiles]
Older version or new version of Acrobat or Reader ?! Change the version from 11.0 to 10.0 for Acrobat X or Reader X
Au Revoir from Albania! 🙂
Message 45 of 68
Jeff_M
Why? Because we don't want to CLEAR the recent documents list. We only want the DST's removed from that list. It's also quite handy to selectively remove drawings opened from a network share that is no longer present....those items in the MRU list will slow down opening Autocad.
Message 46 of 68
neilyj666
Jeff
I'm assuming that Autodesk haven't bothered to fix this long running bug in the 2016 release so does your solution still work (I haven't tried as not got 2016 on this machine yet
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 47 of 68
Jeff_M
Yes, Neil, still works well with 2016.
Message 48 of 68
troma
@rkmcswain wrote:
Jeff -
I would like to add my thanks to you for this tool also.
Unfortuntely, it just defies logic that we even have a need for such tools though.
Why can't Autodesk just FIX this?
Very well put @rkmcswain
That was over two and a half years ago. Now we have an IdeaStation. Maybe if we all work together we can prioritise the mindset of the developers to get some of the basic things fixed, including this one.
If anyone is willing to vote, the place is here.
Mark Green
Working on Civil 3D in Canada
Message 49 of 68
neilyj666
OK thanks - I'll be sure to try it when I move to 2016
Message 50 of 68
CADmgrMike
Awesome software!
Mike Porter
https://provostandpritchard.com/
Message 51 of 68
CADmgrMike
How come you don't have this on the Exchange Apps store making money with it? 🙂
Mike Porter
Message 52 of 68
Jeff_M
@CADmgrMike wrote:
How come you don't have this on the Exchange Apps store....
This app was written before the Exchange existed. It is on my list, however, to figure out how to get it on there. One drawback is that I thought all of the apps are supposed to run inside of AutoCAD. But this one requires AutoCAD to not be running at all. Glad you like it, Mike!
Message 53 of 68
akbcad
Does this work for AutoCAD LT 2016 ? I tried it on AutoCAD 2016 and it worked great, but on LT 2016 the product selection list is empty. Andy
Message 54 of 68
Jeff_M
@akbcad Here is a new version that has been updated to include support for AutoCAD LT.
Message 55 of 68
akbcad
Many thanks, I'll try it out today.
Message 56 of 68
tmullins
Awesome program Jeff. Just bailed us  out here.
Message 57 of 68
Thanks, Jeff!  Just found this.  Works great! (Civil 3D 2014 on Windows 8.1 Pro)
Message 58 of 68
Mecanico14
Hello @Jeff_M
Wonderful application, I just tried in my Autocad Mechanical 2020 and it works without problems. Simple to use and very graphic.
Thank you for your work.
Un saludo.
Mecanico14
Siempre parece imposible hasta que se hace.
Message 59 of 68
Beka_Tchigladze
I click and nothing happens 🥴
Beka Tchigladze
Infrastructure Design Engineer | BIM Automation Developer
Autodesk Developer Network (ADN) Member
Autodesk Certified Professional: Civil 3D & AutoCad
LinkedIn | Autodesk App Store
Message 60 of 68
Jeff_M
@Beka_Tchigladze what are you clicking? Which software? Which version?
