Civil 3D Forum
Remove a block from the drawing block table
1 REPLY 1
4182 Views, 1 Reply
How do you remove a block from the drawing block table? This is so the drawing does not ignore the duplicate block when you bring in an xref'd block but instead allows the xref'd block to come in.
1 REPLY 1
PURGE if the block isn't in use. You can also REName a block that is in
use and the new one will come in with its own name.
HTH
JW
Rail Community
