Raster trough the vertices of the profil line section
I created a setion view profile and I would like to get the informations about kotes and distances in bands of the vertices of my profile line.
In this case I see the raster just of the major stations, but I'd like to see them also in the vertices point of my profile. Is that possible?
In the image attached you can see my problem graphically
Thanks for your time
MMcCall402
Edit your profile data band to be able to show the vertical geometry points you would like to include in the band.
Then edit the band style to display a label for vertical geometry points.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Really thanks fpr your answer but....
actually I would like to modify the "section view plan" and not the longitudinal one.
In fact, if i try to do how you said in the "section profile view bands" I can't find the task about "Geometry points" 😞
https://i.imgur.com/xGngeWf.png
(Geometry point task it would be after "Nebenintervall" --> Minor elevation intervall  - but there is not)
Thanks for your help
Now I try to set on the "interrupt point of inclination" (neigerungsbrechpunkte) here:
http://imgur.com/RETSzae
but he show me just the bands of start and end of the profile:
http://imgur.com/dNOOYiw
What I need (I think) are the "vertices of section line" (Querprofilinien-Scheilpunkte).
So I tried to set them on but he draw me nothing. 😞
MMcCall402
Look here.
Mark Mccall
CAD Mangler
Thank you
but that Layer was already switched on, and this is the same result 😞 :
Anyway I noticed that Layer I can't change type of line and other characteristich.....it is blocked
up
