Hi everyone,
I have a problem when edit featureline. When using "Quick elevation edit" tool, it show correct elevation (41.57, see image 1a and 1b). But when I use "Set grade" tool, it show wrong elevation (12.67, see image 2).
It is the same featureline at the same location,
Can someone help me on this ?
Many thanks,
Solved by AllenJessup. Go to Solution.
It looks like a Units problem. 12.67 meters = 41.57 feet. Check the Drawing Settings from the Toolspace. AECDWGSETUP from the command line to confirm.
Allen Jessup
CAD Manager - Designer
Thank you @AllenJessup
You're welcome.
A quick method I've learned to spot the foot/meter relationship. Divide the meters by 3 and multiply the results by 10.
In my head I say 1/3 of 12.6 is 4.2. Shift the decimal point and 42 is close to 41.57. That makes it likely enough to do the math to confirm it.
Allen Jessup
