Civil 3D Forum
Quick elevation edit and Set grade show different elevation
3 REPLIES 3
tomle_spkt
287 Views, 3 Replies
Hi everyone,
I have a problem when edit featureline. When using "Quick elevation edit" tool, it show correct elevation (41.57, see image 1a and 1b). But when I use "Set grade" tool, it show wrong elevation (12.67, see image 2).
It is the same featureline at the same location,
Can someone help me on this ?
Many thanks,
Tom Le
Civil Outsourcing Engineers
t: (+84) 358 434 730
m: (+84) 358 434 730
e: ceioengineer@gmail.com
CEI Engineers
96 Tay Hoa Street, Ho Chi Minh City
71200, Vietnam
Labels (1)
3 REPLIES 3
AllenJessup
in reply to: tomle_spkt
It looks like a Units problem. 12.67 meters = 41.57 feet. Check the Drawing Settings from the Toolspace. AECDWGSETUP from the command line to confirm.
Allen Jessup
CAD Manager - Designer
tomle_spkt
Thank you @AllenJessup
Tom Le
CEI Engineers
71200, Vietnam
AllenJessup
You're welcome.
A quick method I've learned to spot the foot/meter relationship. Divide the meters by 3 and multiply the results by 10.
In my head I say 1/3 of 12.6 is 4.2. Shift the decimal point and 42 is close to 41.57. That makes it likely enough to do the math to confirm it.
Allen Jessup
Rail Community
