Civil 3D Forum
Quantities from 1 sub-assembly within a corridor using multiple sub-assemblies?
1 REPLY 1
ryan_liebscher
226 Views, 1 Reply
I have an alignment / corridor built using three different a subassemblies (typical trench, fully shored trench, & a hybrid trench) and I'm wanting to acquire the quantities of the  corridor based on each individual subassembly.  Is this possible at all or is it a function of creating boundaries for each section type along the corridor?  I generally would just create boundaries around the needed/varying areas but the corridor changes trench types over 50 times (between two alignments following each other sequentially)...any assistance would be gratefully appreciated!
-Ryan
1 REPLY 1
Gosh, I asked before I looked harder...within the Corridor Properties, on the Parameters Tab, one just needs to uncheck the subassembly they don't need and you have what I'm asking about...I apologize for the needless request...Cheers
Rail Community
