PSLTSCALE Sets itself to 0
- Mute
- Permalink
- Report
I know this topic already has forum posts, but the "accepted solution" in those other posts has turned out not to actually work as a solution 100% of the time. So here's a new topic to try to get a final solution.
Anyway, at random times (switching to the layout, opening the drawing, when the sky turns gray and it begins to rain, etc.) PSTLSCALE will revert to "0" in Civil 3D 2018. In order to get things to print correctly, you have to manually set PSLTSCALE to "1." I have the latest service pack and bug fixes. Several coworkers have had this same problem, but it's hard to identify a pattern for when it happens.
It's been an issue for others on this forum too as you can find here: https://forums.autodesk.com/t5/civil-3d-forum/psltscale-reverts-to-0-at-file-opening/td-p/7820533
Anyone have any updated solutions that will work 100% of the time?
Or at least maybe a solution that works 60% of the time every time?
Thank you,
Running Civil 3D on Windows 10 Pro
Custom PC with: Intel i7-9700K CPU @ 3.60 GHz (8 core); NVIDIA Quadro P1000; 64GB RAM
