FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 5f2e3907h
I need help to solve this problem happens every time I try to use the program
J.FOCHT
Sorry to hear that you received that error. I would suggest checking your graphics card. Please make sure that your graphics card can handle what Autocad is throwing at it. I would also check your drivers and make sure that you have installed and are running the latest driver for your graphics card. It could also be a corrupt file. If that happens you will want to AUDIT and RECOVER the drawing file. Another option would be to uninstall and reinstall the .NET framework. A link on how to do that step is provided below.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
I hope you get everything back up and running soon!
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
