Provide band values to specific chainages in profile
ritesh_trivedi885J6
Message 1 of 16
ritesh_trivedi885J6
I want to create bands for my profile view but want to give values to specific chainages or corresponding chainages only. (see the below screensnap for reference). Please suggest some way to do this.
Replies (15)
Message 2 of 16
brian.strandberg
I'm not seeing any obvious way.  You can add a standard profile view label, drag it down to the band area, and edit the style to suppress the drag leader.
The other method would be to add at a close interval and use CTRL+PICK then delete to remove the ones you don't need.
Neither of these are great ideas, I'm hoping someone has a better one.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 3 of 16
ianjchap
How about trying a ghost profile just for those labels. Add a VP in, puting verticies where you need them, and get your bands to pick up information from that profile, just turn it off or non plotable for presentation. Then overlapping the position of the band with your regular chainage band if need be.
Could work.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
Message 4 of 16
ritesh_trivedi885J6
Thank You for the responses @ianjchap and @brian.strandberg . I'll try both ways and see if it helps.
Message 5 of 16
ritesh_trivedi885J6
@ianjchap . I have a doubt in this. Even after i create a dummy profile and put the vertices where i need them, how do i get values specific to those vertices in bands? My band takes values at specific intervals and not at specific vertices.
Please elaborate on this.
Message 6 of 16
ianjchap
Step 1 - Create a new band copying the Station Band Style - give it a different name (Ghost Chainage - see step 1 image).
Step 2 - Remove Major and Minor Ticks from new band and values (see step 2 images)
Step 3 - Add Geometry points to Ghost Profile where needed - (see step 3 images)
Step 4 - Add gemetry points to the Band and include the new Ghost Profile (see step 4 images
Finally, you should have a bamd with chainage station at given/decided points. Tou could also set elevations to this for other profiles. And for completness you could overlap your station bands.
Hope this helps, there are some minor steps between these instructions that I assume you could be ok with, if not, let me know. And if I've misunderstood any part of what you're after.
Ian Chapman
Message 7 of 16
ritesh_trivedi885J6
understood step 1 and 2 but have difficulty in step 3. None of the elements are visible in this new band after i hide the band values of specific intervals.
can you pls check in my file (attached). I am not sure what's the issue in this.
Message 8 of 16
ianjchap
Looking at your DWG, you haven't created a Ghost VP in any of the profiles.
Which Profile View are you using (there are mutiple), I'll add it in and resend back for your reference.
Ian Chapman
Message 9 of 16
ritesh_trivedi885J6
Please check this file. I have created ghost profile names "LR", "RR" etc. I am able to add station band to one of the ghost profile but not able to add the elevation values.
Please help with regard to this.
Message 10 of 16
ianjchap
You are only two clicks away! 🙂
In your Level Band, you just need to open the Geomery Points:-
And then select Points of Vertical Intersection:-
Ian Chapman
Message 11 of 16
ianjchap
Apologies, I cant post screen grabs as I think we've reached the post limit. Maybe delete the DWGs from ealier posts.
Ian Chapman
Message 12 of 16
ianjchap
I've also realised you could do this by adding Geometry points to your alignment, then you should be able to link the levels to whichever profile you choose. Could be an easier option.
Ian Chapman
Message 13 of 16
ritesh_trivedi885J6
yeah, got this part. Thank You for the help.
Message 14 of 16
ritesh_trivedi885J6
can we avoid creating dummy profile in this case?
Message 15 of 16
ritesh_trivedi885J6
I think these are the only geometry points that we can assign the bands data.
 If i add additional geometry points (like COGO points) then can i assign band values respective to those particular points.
Message 16 of 16
ianjchap
I think if you add verticies on your Alignment where you want band labels to be picked up on your Profile View, you could do it that way also. Then referencing a Profile for the Elevations. That should work too, and may be easier than the Ghost Profile.
I somehow think you can do this using custom labels directly on the Profile View. Something to explore.
Ian Chapman
