Civil 3D Forum
Profile view, water level not inside the box
4 REPLIES 4
met1ns
487 Views, 4 Replies
Hello.
Could someone help me out with water level numbers beeing too far down in a profile view?
I'll post an image showing the issue. I have tried changing back and forward several stuff in band style but can't find the right spot.
In urgent matters i could just explode the band style and manually move the numbers, but I prefer not to.
Help is much preciated. Thank you.
Im using civil3d 2017.
4 REPLIES 4
Jowennl
in reply to: met1ns
Hi @met1ns,
It should be something similar to this. Select the wrong label then right click pick "Edit band style". See attached animated gif below to guide you.
Also see images below as a further step by step guide.
guide 1guide 1guide 2guide 2
Cheers,
Jowenn
met1ns
in reply to: Jowennl
Thank you for your respond.
However I do not have same options as your animation. Please see attached picture.
Any iddeas?
met1ns
Found it now!
I had to chose Pipe > Then water level start and end options and change the Y offset. A bit different in swedish 🙂
Thank you!
Jowennl
in reply to: met1ns
Rail Community
