Hi friends,
I'm struggle with a hatch fill area at the profile.
Cut Area is Fine!
I don't know How can I do to fix it. Anybody could help me please?
Thank in advance
Fabrício
Solved by ACADuser. Go to Solution.
@Anonymous wrote:click on the picture, it is a button on the left for fill area.
That button you mean. I've already do that, isnt' working.
Fabrício
As long as you have created two profiles, ground and design, it must compare and shown in fill area.
Is it possible to share cad file?
@Sinoj.Ravindran wrote:Hi,
Yes. I create two profiles (EG and FG). But at the profile only cut hatch work properly, when I click fill area button, nothing happening.
Sorry but I can't share the file, but I will try to do an other file as a example.
File Attached.
Fabrício
Go into settings from the Toolspace, right-click "Profile View", then click "Edit Feature Settings...". Under "Default Values" set a style for the "Fill Area Shape Style". The button for adding a fill hatch should then work.
@ACADuser wrote:Go into settings from the Toolspace, right-click "Profile View", then click "Edit Feature Settings...". Under "Default Values" set a style for the "Fill Area Shape Style". The button for adding a fill hatch should then work.
I've already try to do that. But ins't working too.
But I've notice that ins't match the style to "Parent Value". I think it is a bug.
Fabricio
Looks like you are in the command settings. Try editing the feature settings...
Try setting the defaults under the root of the Profile View of the tree. As a work around, just create a 'cut ' and set the upper & lower boundaries and shape to show the fill. The cut and fill buttons are only for the styling presets, they have nothing to do with actual work represented.
