Profile doesn t seem on multiple section view
Alas_1234
Alas_1234
    Hi everyone,
I created 2 profile line for road project.
First name is 'yg' it shows  elevation of ground. (Blue)
Second name is 'kırmızı cizgi' . it shows the elevation of my path on the profile.(Red)
After that ı  created sample line and multiple section view. But on the sections only blue profil line(yg) seems, red line(kırmızı cizgi) doesn't seem. Also I can't view red one on group sample properties. So I cant compare my road and ground. How can solve this problem? Thanks.
I attached my working .dwg file.
wfberry
Obviously we have somewhat of a language barrier here.
I  believe the problem you have is the following:
1.  You have a valid original ground surface.
2.  You have a corridor but you did not make a SURFACE from you corridor.
Then when you do your sample lines, you sample the original ground PLUS your new surface (from your corridor).
Bill
Jeff_M
You need to sample the corridor, too. Select one of the sample lines, rt. click select Sample Line Group Properties, on the Sections tab of the form select tghe button to Sample more sources and select the Corridor- (16) and Add it. OK back to the comand line and your sectionviews should update with the corridor now included in the sections.
