Profile Band - Profile 1 - Profile 2 at Pipe Structures
PaulFrancoisStorm
Message 1 of 9
PaulFrancoisStorm
Scenario:
Storm sewer invert level is drawn as profile on an surface profile view along an alignment created for the storm sewer.
Problem:
Create invert to surface band for profile view displaying tics at structures.
Is this even possible?
Replies (8)
Message 2 of 9
ianjchap
You should be able to do this by creating an expression of either the outgoing pipe IL compared to the Rim CL. Or if the base of the chamber is the same as the IL you could use that.
These guy's have also created an add in for this:-
https://www.devotechgroup.com/post/display-depth-to-invert-in-the-profile-view-band
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
Message 3 of 9
obulesub
Hi @PaulFrancoisStorm ,
Did the info from ianjchap  help answer your question?
If it did, it’d be great if you could click the "Accept Solution" button so others can easily find it too.
If you’re still needing more help, feel free to share an update here. The community will be happy to jump in with any next steps to help you get where you need to be.
Obulesu | Community Manager
Message 4 of 9
PaulFrancoisStorm
Please advise me if I am understanding correctly:
  1. It is not possible to create an expression to caclulate the [invert level to surface] of the pipe attachments at the structures using the available properties of structures so that they may automatically show in the band at structure insertion stations.
  2. It is possible to show [pipe inverts to surface] at eregular intervals on bands, just not at structure stations.
  3. Devotec has programmed an app that insets the necessary values at the station values in a band, but this is not replicable in Civil 3D without programming against the API.
Message 5 of 9
Joe-Bouza
invert to surface is kind of like cover. Can cover be used instead?
Joe Bouza
Message 6 of 9
PaulFrancoisStorm
The issue is not that the quantity cannot be calculated, rather that the values need to be displayed as near to the structures as possible.
Message 7 of 9
obulesub
Please let us know if you require any further assistance regarding this matter.  Alternatively, if you found a solution through another method, we would appreciate it if you could share the details with us.
Message 8 of 9
PaulFrancoisStorm
I created expressions and then a pipe network label. It took me longer than I expected but I am happy with the result. Thank you for all the advice.
Message 9 of 9
obulesub
Good afternoon! we hope your request was addressed. If any of the provided comments helped resolve your request, kindly mark the relevant response as the accepted solution. Alternatively, if you found a solution through another method, we would appreciate it if you could share the details with us.
